I looked thru the esri sample code and determined that the "replaceDatasource" function may fix broken links. However, I need to modify the script to fix broken links in many mxds. I hoping someone can spot the problem in this script:import arcpy, os, glob mxds_path = r'S:\\Users Shared\\LOpperman\\Town Scale MXDs\\MXDs\\targetlayers\\' layer_name = r'dams' data_frame = r'Primary' for infile in glob.glob(os.path.join( mxds_path, "*.mxd" )): mxd = arcpy.mapping.MapDocument(infile) for df in arcpy.mapping.ListDataFrames(mxd, data_frame): for lyr in arcpy.mapping.ListLayers(mxd, "", df): lyr.replaceDataSource("dams") mxd.save()
