This is my first attempt at a Javascript app, so I am very new at this. We are trying to upgrade an old MapObjects site that sees a lot of traffic. Mainly, people click on a parcel and it shows them all the information about that parcel. There are several tables that are linked to the parcel layer. I have tried creating a Map Service (hosted on our server) that has the parcel layer with a relationship class to the tables, and I have also tried creating a feature layer (hosted on AGOL) that is created from the parcels with those same relationship classes. Neither of these have worked. I may not have set these up correctly either. If I point the url to a parcel layer with no related tables, it works. As soon as I change that url to the map service or the feature layer with related tables, nothing shows in the popup. What is the best way to go about getting a popup with related tables? Any help is appreciated.
<SPAN class="keyword token">var</SPAN> parcels <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fservices3.arcgis.com%2FXXXXXXXXXXXXXX%2Farcgis%2Frest%2Fservices%2FParcels%2FFeatureServer" target="_blank">https://services3.arcgis.com/xyz/arcgis/rest/services/Parcels/FeatureServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"taxlots"</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
popupTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PopupTemplate()</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Parcel Number: "</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ASSESSOR_N"</SPAN><SPAN class="punctuation token">,</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Assessor Number"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"relationships/0/FIRST_NAME"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"First Name"</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"relationships/0/LAST_NAME"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Last Name"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
