The following message is appearing in my log file. Not sure where to begin troubleshooting. This is a new server, clean install of Windows Server 2012 r2. ArcGIS Server 10.3 and GeoEvent processor installed. Any advice on where to look for the cause of this error would be greatly apprecitated! Thanks!
2015-05-21 13:15:17,043 | ERROR | Thread-45 | ConnectionHandler | .lyra.internal.ConnectionHandler 125 | 243 - com.esri.ges.framework.messaging.jms-messaging - 10.3.0 | Failed to create connection cxn-160971 java.net.ConnectException: Connection refused: connect<BR /> at java.net.DualStackPlainSocketImpl.connect0(Native Method)[:1.7.0_65]<BR /> at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)[:1.7.0_65]<BR /> at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)[:1.7.0_65]<BR /> at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)[:1.7.0_65]<BR /> at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)[:1.7.0_65]<BR /> at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)[:1.7.0_65]<BR /> at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.7.0_65]<BR /> at java.net.Socket.connect(Socket.java:579)[:1.7.0_65]<BR /> at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:618)[:1.7.0_65]<BR /> at com.rabbitmq.client.impl.FrameHandlerFactory.create(FrameHandlerFactory.java:32)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:588)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at net.jodah.lyra.internal.ConnectionHandler$3.call(ConnectionHandler.java:233)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at net.jodah.lyra.internal.ConnectionHandler$3.call(ConnectionHandler.java:227)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at net.jodah.lyra.internal.RetryableResource.callWithRetries(RetryableResource.java:50)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at net.jodah.lyra.internal.ConnectionHandler.createConnection(ConnectionHandler.java:227)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at net.jodah.lyra.internal.ConnectionHandler.createConnection(ConnectionHandler.java:115)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at net.jodah.lyra.Connections.create(Connections.java:68)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at com.esri.ges.messaging.jms.AmqpMessagingFactory$ConnectionEstablisher.run(AmqpMessagingFactory.java:669)[243:com.esri.ges.framework.messaging.jms-messaging:10.3.0]<BR /> at java.lang.Thread.run(Thread.java:745)[:1.7.0_65]
