I'm running into a problem when attempting to see the graphicprovider for a graphic layer to show the results of an IdentifyTask in my program. I'm adding the graphic layer (along with a bunch of other layers) in the initialize code for the page.I tried using the Identify sample from the Resource page (version 1.3) to run a test. When I click on a polygon with the original sample code, the polygon gets shaded with the symbology as expected. However, when I programmatically add in the graphic layer holding the lastIdentifyResultGraphic, the polygon does not get shaded as expected.Where am I going wrong in this code?
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
xmlns:mx="http://www.adobe.com/2006/mxml"
xmlns:esri="http://www.esri.com/2008/ags"
layout="vertical"
styleName="plain"
pageTitle="Identify Features on the Map" initialize="init();">
This sample shows how to identify features with a MapClick and the Identify task.
The IdentifyParameters designate which layers are being identified.
Identify operations can potentially return a lot of information
depending on the number of layers being identified and a given tolerance.
The tolerance is the number of pixels a feature is allowed to lie away
from the clicked point in order to be counted as a result.
In this sample, when user clicks the map, an "Identify" task is executed.
When the task finishes executing, the identifyCompleteHandler function loops
through the features in the IdentifyResult and adds them to the map.
<mx:Script>
<![CDATA[
import com.esri.ags.Graphic;
import com.esri.ags.events.MapMouseEvent;
import com.esri.ags.geometry.Geometry;
import com.esri.ags.symbol.InfoSymbol;
import com.esri.ags.tasks.IdentifyParameters;
import com.esri.ags.tasks.IdentifyResult;
import mx.controls.Alert;
import mx.rpc.AsyncResponder;
[Bindable]
private var lastIdentifyResultGraphic:Graphic;
private var layerGraphics:GraphicsLayer = new GraphicsLayer;
private function init():void
layerGraphics.graphicProvider = lastIdentifyResultGraphic;
myMap.addLayer(layerGraphics);
private function mapClickHandler(event:MapMouseEvent):void
clickGraphicsLayer.clear();
var identifyParams:IdentifyParameters = new IdentifyParameters();
identifyParams.returnGeometry = true;
identifyParams.layerIds = new Array([2]);
identifyParams.tolerance = 3;
identifyParams.width = myMap.width;
identifyParams.height = myMap.height;
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = myMap.extent;
identifyParams.spatialReference = myMap.spatialReference;
var clickGraphic:Graphic = new Graphic(event.mapPoint, clickPtSym);
identifyTask.execute(identifyParams, new AsyncResponder(myResultFunction, myFaultFunction, clickGraphic));
clickGraphicsLayer.add(clickGraphic);
private function myResultFunction(results:Array, clickGraphic:Graphic = null):void
if (results && results.length > 0)
var result:IdentifyResult = results[0];
var resultGraphic:Graphic = result.feature;
switch (resultGraphic.geometry.type)
case Geometry.MAPPOINT:
resultGraphic.symbol = smsIdentify;
break;
case Geometry.POLYLINE:
resultGraphic.symbol = slsIdentify;
break;
case Geometry.POLYGON:
resultGraphic.symbol = sfsIdentify;
break;
lastIdentifyResultGraphic = resultGraphic;
// update clickGraphic (from mouse click to returned feature)
clickGraphic.symbol = new InfoSymbol(); // use default renderer
clickGraphic.attributes = resultGraphic.attributes;
private function myFaultFunction(error:Object, clickGraphic:Graphic = null):void
Alert.show(String(error), "Identify Error");
</mx:Script>
<!-- start declarations -->
<!-- Symbol for where the user clicked -->
<esri:SimpleMarkerSymbol id="clickPtSym" style="x" color="0xFF0000" size="12"/>
<!-- Symbol for Identify Result as Polyline -->
<esri:SimpleLineSymbol id="slsIdentify" style="solid" color="0x00FF00" width="2" alpha="1"/>
<!-- Symbol for Identify Result as Point -->
<esri:SimpleMarkerSymbol id="smsIdentify" style="diamond" color="0x00FF00" size="15"/>
<!-- Symbol for Identify Result as Polygon -->
<esri:SimpleFillSymbol id="sfsIdentify"/>
<!-- Identify Task -->
<esri:IdentifyTask id="identifyTask"
concurrency="last"
url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer"/>
<!-- end declarations -->
<esri:Map id="myMap" mapClick="mapClickHandler(event)">
<esri:extent>
<esri:Extent xmin="-120" ymin="30" xmax="-100" ymax="50">
<esri:SpatialReference wkid="4326"/>
</esri:Extent>
</esri:extent>
<esri:ArcGISDynamicMapServiceLayer
url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
<!--<esri:GraphicsLayer graphicProvider="{lastIdentifyResultGraphic}"/>-->
<esri:GraphicsLayer id="clickGraphicsLayer"/>
</esri:Map>
</mx:Application>
