In my app using ArcGIS Runtime SDK for Android 100.0.0 I’m loading a local TileCache from a TPK file into my MapView as a basemap. Before loading the TileCache I’m adding a “DoneLoadingListener” (Runnable) and a LoadStatusChangedListener to the TileCache to get notified when the loading is done. It is my understanding that these listeners should be called whether the loading succeeds or not and that by checking the LoadStatus on the TileCache I can tell if it loaded successfully or not. On some occasions though, seemingly randomly, the callbacks aren’t called at all. What may cause the callbacks to not be called and how can I monitor what is going on if I can’t get notified using the listeners?
Here is the code
File baseMap = getPermanentPathForMapType(MapDataType.BASE_MAP);
TileCache tileCache = new TileCache(baseMap.getPath());
tileCache.loadAsync();
tileCache.addDoneLoadingListener(new Runnable() {
@Override
public void run() {
Log.i(TAG, "LOAD DONE"); // Sometimes not called
tileCache.addLoadStatusChangedListener(new LoadStatusChangedListener() {
@Override
public void loadStatusChanged(LoadStatusChangedEvent loadStatusChangedEvent) {
Log.i(TAG, "LOAD STATUS CHANGED TO " + loadStatusChangedEvent.getNewLoadStatus().toString()); // Sometimes not called
Log.i(TAG, tileCache.getLoadStatus().toString()); // LOADING
Regards,
Henrik
