The web map that I'm using to build my dashboard has multiple layers. When I load the dashboard it uses the layers that were turned on when saved as the default display layers. For this dashboard, I want to display a different layer in the web map as the default. I can add the layer to the layer selection, but then I have to change the layer whenever the dashboard. I would prefer to not save a new web map with that as the default layer as the workaround.
