I'm attempting to manually create a new FeatureLayer from client side Graphics. I cannot figure out where I am going wrong, but the FeatureLayer is not visible on the map. My code is below:
<SPAN class="doctype token"><!DOCTYPE html></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>CreateLayer<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="selector token">html,
body,
#ViewMap_div</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> auto<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 95%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 95%<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.13/<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.13/esri/themes/light/main.css<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> WebMap<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// create the map view</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'hybrid'</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ViewMap_div"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">76</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">37</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
extent<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN>
<SPAN class="keyword token">var</SPAN> pointGL <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"point"</SPAN><SPAN class="punctuation token">,</SPAN>
longitude<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">76</SPAN><SPAN class="punctuation token">,</SPAN>
latitude<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">37</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
attributes<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
ObjectID<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
ProjectName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'ProjA'</SPAN><SPAN class="punctuation token">,</SPAN>
SiteName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'SiteA'</SPAN>
<SPAN class="keyword token">var</SPAN> fl <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
source<SPAN class="punctuation token">:</SPAN> pointGL<SPAN class="punctuation token">,</SPAN>
renderer<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple"</SPAN><SPAN class="punctuation token">,</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple marker"</SPAN><SPAN class="punctuation token">,</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"green"</SPAN><SPAN class="punctuation token">,</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"red"</SPAN><SPAN class="punctuation token">,</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN>
fields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"oid"</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ProjectName"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ProjectName"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"string"</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SiteName"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SiteName"</SPAN><SPAN class="punctuation token">,</SPAN>
objectIDField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>fl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">/* create GraphicsLayer for the pointGL Graphic
var gl = new GraphicsLayer({
graphics: pointGL
map.add(gl);
*/</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<div id = "ViewMap_div"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>If you un-comment the section at the end creating a GraphicsLayer from the pointGL Graphic, it is clear that the Graphic is formed properly. For some reason, the new FeatureLayer is not being created, or is not displaying on the map.
The ultimate goal is to take user-defined lat/long coordinates, create a Graphic from them, then create a new FeatureLayer from that. If someone could point me in the right direction, I'd really appreciate it.
Thank you.
