Hi All,
The objective is to create a code that allow me to delete polygons if they intersect.
Scenario:
- Keep the first one.
- Check the second one if intersect delete the second if not keep it.
- Check the third one if intersect delete if not keep it.
I create a code in Javascript using service network area for arcgis online that you can test the result (Working but not deleting the intersection) the problem is i don't know how to check the intersection and deleted from the list if someone can help i will be very greatful.
Below the code:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Dispatch Algorithm Implementation</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
<style>
body,html,#main{margin:0;padding:0;height:100%;width:100%;}
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://js.arcgis.com/3.9/"></script>
<script>
dojo.require("esri.map");
dojo.require("esri.tasks.servicearea");
dojo.require("dijit.dijit");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.form.HorizontalSlider");
dojo.require("dijit.form.HorizontalRuleLabels");
dojo.require("dijit.form.HorizontalRule");
dojo.require("dijit.form.Button");
dojo.require("esri.graphic");
dojo.require("esri.tasks.geometry");
dojo.require("esri.layers.graphics");
dojo.require("esri.Color");
var map, serviceAreaTask, params, clickpoint, gsvc;
function init() {
esri.config.defaults.io.proxyUrl = "/proxy";
map = new esri.Map("map", {
basemap: "streets",
center: [-122.447, 37.781],
zoom: 14
params = new esri.tasks.ServiceAreaParameters();
params.defaultBreaks= [1];
params.outSpatialReference = map.spatialReference;
params.returnFacilities = true;
serviceAreaTask = new esri.tasks.ServiceAreaTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Service Area");
gsvc = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
dojo.connect(dijit.byId("hslider"), "onChange", updateHorizontalLabel);
updateHorizontalLabel();
// Create function that updates label when changed
function updateHorizontalLabel() {
// Get access to nodes/widgets we need to get/set values
var hSlider = dijit.byId("hslider");
var label = dojo.byId("decValue");
// Update label
label.innerHTML = hSlider.get("value");
params.defaultBreaks = [hSlider.value/60];
// if (typeof clickpoint != 'undefined') {
// AddDT(clickpoint);
//Clears DTP
function ClearDTP() {
map.graphics.clear();
function AddDTP() {
map.graphics.clear(); //clear existing graphics
//define the symbology used to display the results and input point
var pointSymbol = new esri.symbol.PictureMarkerSymbol({
"angle":0,
"xoffset":0,
"yoffset":10,
"type":"esriPMS",
"url":"http://icons.iconarchive.com/icons/aha-soft/standard-transport/256/police-car-icon.png",
"contentType":"image/png",
"width":30,
"height":30
var m_mapPoint = [];
m_mapPoint[1] = new esri.geometry.Point([-122.447, 37.781],new esri.SpatialReference({ wkid:4326 }));
m_mapPoint[2] = new esri.geometry.Point([-122.457, 37.791],new esri.SpatialReference({ wkid:4326 }));
m_mapPoint[3] = new esri.geometry.Point([-122.450, 37.785],new esri.SpatialReference({ wkid:4326 }));
m_mapPoint[4] = new esri.geometry.Point([-122.452, 37.775],new esri.SpatialReference({ wkid:4326 }));
m_mapPoint[5] = new esri.geometry.Point([-122.452, 37.791],new esri.SpatialReference({ wkid:4326 }));
m_mapPoint[6] = new esri.geometry.Point([-122.450, 37.777],new esri.SpatialReference({ wkid:4326 }));
m_mapPoint[7] = new esri.geometry.Point([-122.470, 37.777],new esri.SpatialReference({ wkid:4326 }));
var location1 = new esri.Graphic(m_mapPoint[1],pointSymbol);
var location2 = new esri.Graphic(m_mapPoint[2],pointSymbol);
var location3 = new esri.Graphic(m_mapPoint[3],pointSymbol);
var location4 = new esri.Graphic(m_mapPoint[4],pointSymbol);
var location5 = new esri.Graphic(m_mapPoint[5],pointSymbol);
var location6 = new esri.Graphic(m_mapPoint[6],pointSymbol);
var location7 = new esri.Graphic(m_mapPoint[7],pointSymbol);
map.graphics.add(location1);
map.graphics.add(location2);
map.graphics.add(location3);
map.graphics.add(location4);
map.graphics.add(location5);
map.graphics.add(location6);
map.graphics.add(location7);
var features = [];
features.push(location1);
features.push(location2);
features.push(location3);
features.push(location4);
features.push(location5);
features.push(location6);
features.push(location7);
var facilities = new esri.tasks.FeatureSet();
facilities.features = features;
params.facilities = facilities;
//solve
serviceAreaTask.solve(params,function(solveResult){
var result = solveResult;
var serviceAreaSymbol = new esri.symbol.SimpleFillSymbol(
esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(
esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([232,104,80]), 2
new dojo.Color([232,104,80,0.25])
var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([232,104,80]), 2),new dojo.Color([232,104,80,0.25]));
var polys = solveResult.serviceAreaPolygons;
var index=0;
// Filters all the polygons that intersect each other
filterIntersections(polys, index);
// Put the remaining polygons on the map
dojo.forEach(polys, function(poly){
poly.setSymbol(polygonSymbol);
map.graphics.add(poly);
}, function(err){
console.log(err.message);
function filterIntersections(polys, index)
var polysIntersect = [];
for (var j=index+1; j<polys.length; j++)
polysIntersect.push(polys.geometry);
if(polysIntersect.length == 0)
// End of filtering
return;
// Call intersect service
gsvc.intersect(polysIntersect, polys[index].geometry, function(obj){
console.log(obj);
Delete from polys list all polygons that intersect with polys[index]
when we delete a polygon from polys -> index--;
this part here i don't know how to do ??
// Next polygon
index++;
}, function(err){
dojo.ready(init);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0px;">
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'">
<b>Choose your threshold to find the appropriate dispatch:</b>
<div style="width: 360px; margin: 10px">
<!-- create rules and labels above horizontal slider -->
<ol data-dojo-type="dijit.form.HorizontalRuleLabels"
data-dojo-props="
container: 'topDecoration',
style: 'height: 1.2em; font-weight: bold; margin: 0 12px;'">
<li>0</li>
<li>0:20</li>
<li>0:40</li>
<li>1:00</li>
<li>1:20</li>
<li>1:40</li>
<li>2:00</li>
</ol>
<div data-dojo-type="dijit.form.HorizontalRule"
data-dojo-props="
count: 7,
style: 'height: 5px; margin: 0 12px;'">
</div>
<input id="hslider" value="60" type="range"
data-dojo-type="dijit.form.HorizontalSlider"
data-dojo-props="
minimum: 0,
maximum: 120,
showButtons: false,
discreteValues: 25">
<div style="padding-top: 10px; text-align: center;">Travel time: <strong id="decValue"></strong> Seconds</div>
<br><br>
<label class="form_col" for="NumberPC">Please Enter a Number of Patrol Car:</label>
<input name="NumberPC" id="NumberPC" type="text" size="10" />
<br><br>
<label class="form_col" for="zone">Zone :</label>
<select name="zone" id="zone">
<option value="none">Select your zone</option>
<option value="z1">zone 1</option>
<option value="z2">zone 2</option>
<option value="z3">zone 3</option>
</select>
<br><br>
<button onclick="AddDTP();">Dispatch</button>
<button onclick="ClearDTP();">Clear Dispatch</button>
</div>
</div>
<div id="map" dojotype="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
</div>
</body>
</html>
