I have a map with about 15 layers on it that are all part of a single feature service. All point to a single sql db. I can see and edit all of them in a webmap no problem.
When I try to download the map in Collector I get this error
"The map failed to download with the message: Failed to create replica. Multiple layers are referencing a dataset, which is not supported"
Also note the download stays in the android notification bar forever
Tried using ArcGIS Online and Portal 10.3 (and server 10.3).
I made a new map with just one of these layers and it works fine. I am pointing to the exact same Feature Service just using a /10.
I can find nothing in the help or here on this.
I think it means I can only have one editable layer in a map when going offline. But that seems strange. Not a very useful app if I can only edit one thing.
Is there any documentation on this? I would like to know how to work around it or what all my limits are. Do I need to publish one layer per feature service (and if I do can I add multiple feature services to a map then download) or have one feature service and the rest map service?
