I have setup ArcSDE 10.1 on postgres 9.0 and added some shapefiles with shp2sde. When I try to add the layer to the map panel of ArcMap 10.1 I get the following error message :
One or more layers failed to draw: sde.sde.medford_streets: Invalid SQL syntax [ERROR: syntax error at or near "." LINE 1: ...ord_streets.geom , sde.medford_streets. from sde.sde.medfo... ^ ::SQL state: 42601] [sde.sde.medford_streets] ---
Has anyone encountered this problem? I found this (NIM081670 - Data imported into SDE using the 'shp2sde' command.. ), but I do not have the license required for the Register with Geodatabase tool. So any other solutions or suggestions are very welcome. Thanks!
