I'm trying to create a DDP export to PDF script that uses the ESRI Example from South Kingstown, RI, and when I run my script I get this error:Runtime error Traceback (most recent call last): File "<string>", line 17, in <module> WindowsError: [Error 5] Access is denied: 'R:\\GIS\\...\\PDF'
I thinks due to this bit of code:if multiPage == "true": if os.path.exists(outputPDF): os.remove(outputPDF) #Create new FinalMapBook that results will be appeneded into finalMapBook = arcpy.mapping.PDFDocumentCreate(outputPDF)
I have full access to the drive and the folder. I tried my local drive and I get the same error. Any ideas?
