Symblize Point Layer
All,
I am in a unique situation to symbolize point layer.
For example, I have a point Layer that has following attributes.
Field1, Field2, X, Y, Field3, Field4, Field5
1,1,-71.438467,41.825945,egsq,price rite - eagle square,0,0,0
0,2,-71.438467,41.825945,016495,PRICE RITE EAGLE SQUARE,16495,0,0
0,0,-71.438511,41.826,50
2,0,-71.438041,41.82638,0
I wanted to symbolize based upon Field values with the following criteria.
Field3 = 50 , Then color is Green
Field3 = 0, Then color is blue.
How to achieve this using IUniqueValueRenderer?
I am using following code snippet ...
#region loop for featurecursor
while (!(i == n))
//System.Threading.Thread.Sleep(1000);
IFeature pFeat = default(IFeature);
pFeat = pFeatCursor.NextFeature();
ISimpleRenderer simpleRender = default(ISimpleRenderer);
simpleRender = new SimpleRenderer();
IUniqueValueRenderer pRender = default(IUniqueValueRenderer);
pRender = new UniqueValueRenderer();
pRender.FieldCount = 1;
pRender.set_Field(0, "Field1");
pRender.FieldDelimiter = ",";
pRender.UseDefaultSymbol = false;
SimpleMarkerSymbol markerSYmbol = new SimpleMarkerSymbol();
IRgbColor color = new RgbColor();
int indefOfField = pFeat.Fields.FindField("Field5");
int fieldValue = 0;
object TPTYpeValue = pFeat.get_Value(indefOfField);
string tpTypeVal = TPTYpeValue.ToString();
bool isIntger = int.TryParse(tpTypeVal, out fieldValue);
if (isIntger) //Check to see, if it's integer first
if (fieldValue == 0) //If value is 0 then assign Red color
//markerSYmbol.Color = (IColor)color;
markerSYmbol.Color = new RgbColorClass {Red = 255, Green = 0, Blue = 0};
markerSYmbol.Style = ESRI.ArcGIS.Display.esriSimpleMarkerStyle.esriSMSCircle;
markerSYmbol.Size = 6;
else
markerSYmbol.Size = 20;
markerSYmbol.Color = new RgbColorClass { Red = 0, Green = 0, Blue = 255 };
else
markerSYmbol.Size = 14;
string w = null;
w = iRedField + "," + iGreenField + "," + iBlueField;
ValFound = false;
for (uh = 0; uh <= (pRender.ValueCount - 1); uh++)
if (pRender.Value[uh] == w)
NoValFound = true;
break;
if (!ValFound)
ESRI.ArcGIS.Display.ISymbol symbol = (ESRI.ArcGIS.Display.ISymbol)markerSYmbol; // Explicit Cast
pRender.AddValue(w, "", symbol);
pRender.set_Symbol(w, symbol);
//Symbolize Feature
simpleRender.Symbol = symbol;
ESRI.ArcGIS.Carto.IFeatureRenderer _featRender = (ESRI.ArcGIS.Carto.IFeatureRenderer)simpleRender;
pLayer.Renderer = _featRender;
//_featRender.SymbolByFeature.Draw = symbol;
//pLayer.MaximumScale = 3000.00;
//pLayer.MinimumScale = 500000.00;
#region LabelFeature
stdole.IFontDisp font = new stdole.StdFontClass() as stdole.IFontDisp;
font.Name = "Times New Roman";
font.Bold = false;
font.Size = 10;
IAnnotateLayerPropertiesCollection _layerAnnotate;
_layerAnnotate = pLayer.AnnotationProperties;
IElementCollection placedElement = new ElementCollection();
IElementCollection unplacedElement = new ElementCollection();
IAnnotateLayerProperties _layerAnnotateProps;
_layerAnnotate.QueryItem(0, out _layerAnnotateProps, out placedElement, out unplacedElement);
//Min / Max Scale for Layer Labels
_layerAnnotateProps.AnnotationMaximumScale = 3000.00;
_layerAnnotateProps.AnnotationMinimumScale = 500000.00;
ILabelEngineLayerProperties pLayerLabelEngineProps;
pLayerLabelEngineProps = (ILabelEngineLayerProperties)_layerAnnotateProps;
pLayer.DisplayAnnotation = true;
#endregion
i = i + 1;
#endregion
IUID pUID = new UIDClass();
pUID.Value = "{683C994E-A17B-11D1-8816-080009EC732A}";
//** This makes the layer properties symbology tab show
//** show the correct interface.
IRendererPropertyPage pRPpage = new UniqueValuePropertyPageClass();
pLayer.RendererPropertyPageClassID = pUID as UIDClass; // pRPpage.ClassID;
//Add Layer to static list to acces in future
k++;
//Release feature cursor
//Marshal.ReleaseComObject(pFeatCursor);
#endregion
//Add Layer to Map
pMap.AddLayer(pLayer);
//** Refresh the TOC
pMxDoc.ActiveView.ContentsChanged();
pMxDoc.UpdateContents();
//** Draw the map
pMxDoc.ActiveView.Refresh();
#endregion
Thanks and Regards,
Shailesh Gavathe
