While investigating version 10.2.6 I have noticed a regression in the rendering of a TextSymbol in my code. I am seeing three issues, enumerated below. Related code at the bottom of the post. Any ideas on why these issues are occurring? Are they known issues? I could not find anything in the release notes.
1. Placement of the TextSymbol is different in 10.2.6 than it was in 10.2.4. In 10.2.4 it was right justified. In 10.2.6 it is now centered. See screenshots. The HorizontalTextAlignment property does not have an affect.
2. There is leftover TextSymbol when clearing the TextSymbol and creating a new one. See screenshots
3. The TextSymbol is sometimes cut off (half of it will be missing).
10.2.4
10.2.6
private async void MeasureLocationAsync(object sender, RoutedEventArgs e)
while (true)
// get or create graphics layer to display user measurement objects
var measureLayer = (GraphicsLayer) MyMapView.Map.Layers[MeasureLayerID];
if (measureLayer == null)
measureLayer = new GraphicsLayer {ID = MeasureLayerID};
measureLayer.RenderingMode = GraphicsRenderingMode.Static;
MyMapView.Map.Layers.Add(measureLayer);
var taskLoadLayer = MyMapView.LayersLoadedAsync(new List<Layer> {measureLayer});
var taskDrawShape = MyMapView.Editor.RequestPointAsync();
try
await Task.WhenAll(taskLoadLayer, taskDrawShape);
catch (TaskCanceledException)
// editor operation was cancelled. break out of this
return;
var point = taskDrawShape.Result;
var wgs84Location = (MapPoint)GeometryEngine.Project(point, SpatialReferences.Wgs84);
// clear existing items from measurement layer
measureLayer.Graphics.Clear();
// create symbol
var markerSymbol = new SimpleMarkerSymbol
Color = Colors.Orange,
Size = 16,
Outline = new SimpleLineSymbol()
Color = Colors.Black,
Width = 3
var symbolGraphic = new Graphic(point, markerSymbol);
// create text label
var textSymbol = new TextSymbol
BackgroundColor = Colors.Black, // this doesn't work when rendering mode is static, bug in esri?
XOffset = 10,
YOffset = 10,
HorizontalTextAlignment = HorizontalTextAlignment.Right,
Font = new SymbolFont(MeasurePostionButton.FontFamily.Source, 24, SymbolFontStyle.Normal, SymbolTextDecoration.None, SymbolFontWeight.Bold),
Text = $"{wgs84Location.X}, {wgs84Location.Y}"
var textGraphic = new Graphic(point, textSymbol);
measureLayer.Graphics.Add(symbolGraphic);
measureLayer.Graphics.Add(textGraphic);
