I am trying to publish vector tiles for a sizable feature class (100,000+ line records) through ArcGIS Pro. I have tried to publish on two different computers and always receive a "Staging failed" error.
Here is my workflow: The data is loaded into a Pro project, then I go to "Share" and "Web Layer". Under General, I select "Copy all data" and "Vector tile". Under Configuration, I set it to "ArcGIS Online/ Bing Maps/ Google Maps" with levels of detail 14-19. I use Indexed tiling format with an index polygon created from the "Create Vector Tile Index" tool.
I am using ArcGIS Pro 2.0.0
Any ideas what might be wrong? Or is there a way to get more details on the failure than "Staging failed" (no details show up in Geoprocessing History)?
