sing ArcGIS 10.2 for Desktop, I have some Shapefiles which I have no idea why their Geometry column (shape) contain ZM! now I need to remove all those ZM and get a clean polygon instead.
I thought I can use the FeatureClassToShapefile_conversion() but not sure how to disabled both Output has Z Values and Output has M Values through following ArcPy
<SPAN class="com" style="color: #808080;"># Import system modules</SPAN><SPAN class="pln" style="color: #000000;">
</SPAN><SPAN class="kwd" style="color: #00008b;">import</SPAN><SPAN class="pln" style="color: #000000;"> arcpy </SPAN><SPAN class="kwd" style="color: #00008b;">from</SPAN><SPAN class="pln" style="color: #000000;"> arcpy </SPAN><SPAN class="kwd" style="color: #00008b;">import</SPAN><SPAN class="pln" style="color: #000000;"> env
</SPAN><SPAN class="com" style="color: #808080;"># Set environment settings</SPAN><SPAN class="pln" style="color: #000000;"> env</SPAN><SPAN class="pun" style="color: #000000;">.</SPAN><SPAN class="pln" style="color: #000000;">workspace </SPAN><SPAN class="pun" style="color: #000000;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"C:/data"</SPAN><SPAN class="pln" style="color: #000000;">
</SPAN><SPAN class="com" style="color: #808080;"># Set local variables</SPAN><SPAN class="pln" style="color: #000000;">
inFeature </SPAN><SPAN class="pun" style="color: #000000;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #000000;">[</SPAN><SPAN class="str" style="color: #800000;">"climate.shp"</SPAN><SPAN class="pun" style="color: #000000;">]</SPAN><SPAN class="pln" style="color: #000000;"> outLocation </SPAN><SPAN class="pun" style="color: #000000;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"C:/output"</SPAN><SPAN class="pln" style="color: #000000;">
arcpy</SPAN><SPAN class="pun" style="color: #000000;">.</SPAN><SPAN class="typ" style="color: #2b91af;">FeatureClassToShapefile_conversion</SPAN><SPAN class="pun" style="color: #000000;">(</SPAN><SPAN class="pln" style="color: #000000;">inFeatures</SPAN><SPAN class="pun" style="color: #000000;">,</SPAN><SPAN class="pln" style="color: #000000;"> outLocation</SPAN><SPAN class="pun" style="color: #000000;">)</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN>
