I am trying to write a code that will loop through a gdb listing all tables, rasters and featureclasses. It must also list all fields and their types in the featureclasses and print them. I can get everything to print properly with the exception of the ListField. Once I started playing with that command it went down hill. I think the problem lies in determining the dataset for the ListField to run through, I do not know how to tell the ListField to target every featureclass in the designated gdb.
import arcpy, os
### Set Workspace
##gdbpath = raw_input ('Enter File Full Pathname to Geodatabase')
##if arcpy.Exists(gdbpath):
## print 'GDB Found'
##else:
## exit('Invalid Pathname')
gdbpath = 'C:\Users\Stanton\Documents\GISProgramming\Database\Database\Corvallis.gdb'
arcpy.env.workspace = gdbpath
basepath = os.path.basename(gdbpath)
dirpath = os.path.dirname(gdbpath)
print '='*60
print '='*60
# GDB Name
print 'File Geodatabase Name: ' + basepath
#GDB Directory
print 'File Geodatabase Directory: ' + dirpath
# Number of Feature Classes
fcList = arcpy.ListFeatureClasses()
numberFC = len(fcList)
print 'Number of FeatureClasses: ' + str(numberFC)
# Number of Tables
tableList = arcpy.ListTables()
numberTables = len(tableList)
print 'Number of Tables: ' + str(numberTables)
# Number of Rasters:
rasterList = arcpy.ListRasters()
numberRasters = len (rasterList)
print 'Number of Rasters: ' + str(numberRasters)
print '='*60
print '='*60
#Table Names
tableName = tableList
if not tableName:
print 'Tables:'
print '\tNone\n'
else:
print 'Tables:'
for fc in tableName:
print '\t' + fc + '\n'
#Raster Names
rasterName = rasterList
if not rasterName:
print 'Rasters:'
print '\tNone\n'
else:
print 'Rasters:'
for fc in rasterName:
#FeaturClassNames and Field Names
fcName = fcList
if not fcName:
print 'FeatureClasses:'
print '\tNone\n'
else:
dataset = gdbpath
fieldName = arcpy.ListFields(dataset,'*','All')
for fc in fcList:
print '\t' + fc + fieldName
