Greetings, I am writing some code that puts in an expression into a SelectLayerByAttribute statement and am running into a problem. I am generating a running sequence of numbers (closNum) that are made into text. (using an SDE geodatabase FYI)
closNum = "'" + '{:05d}'.format(i) + "'"
When I print that out it looks like closNum = '00000'
I generate an expression statement expression = '"' + ' LABEL = ' + "'" + closNum + "'"+ '"' which prints out as " LABEL = '00000'"
What I would like to do is put that into my layer selection query arcpy.SelectLayerByAttribute_management(closureLyr, "NEW_SELECTION", expression)
So when I run that, I get an invalid expression error, but if I run arcpy.SelectLayerByAttribute_management(closureLyr, "NEW_SELECTION", " LABEL = '00000'"), it works just fine.
Somehow I am missing something but I can't figure out what.
Any help would be awesome
Actual code below
import string, arcpy
from arcpy import env
inFC = 'Database Connections/GISTLMD on DNRHLN6341 as TLMD_FMB_MGR - FMB_RoadInventory.sde/GISTLMD.TLMD_DO.FMB_RoadClosures'
closureLyr = 'closureLyr'
count = 1
arcpy.MakeFeatureLayer_management(inFC,closureLyr)
for i in range(0,10,1):
# print '{:05d}'.format(i)
expression = '"LABEL = ' + closNum + '"'
arcpy.AddMessage(expression)
# arcpy.SelectLayerByAttribute_management(closureLyr, "NEW_SELECTION", "LABEL = '00000'")
result = arcpy.GetCount_management(closureLyr)
cnt = int(result.getOutput(0))
if cnt == 0:
arcpy.AddMessage(expression + ' is missing')
count = count + 1
#count = count + 1
if count == 5 :
break
Donna
