In the help for ArcGIS Pro 2.4's
Python CIM access there is "Example 3: Modify layer symbology" which has this code:
# Reference a project, map, and layer using arcpy.mp
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('Trail Routes')[0]
lyr = m.listLayers('Loops')[0]
# Return the layer's CIM definition
cim_lyr = lyr.getDefinition('V2')
# Modify the color, width and dash template for the SolidStroke layer
symLvl1 = cim_lyr.Renderer.Symbol.Symbol.SymbolLayers[0]
symLvl1.Color.Values = [250, 250, 40, 50]
symLvl1.Width = 8
ef1 = symLvl1.Effects[0] #Note, deeper indentation
ef1.DashTemplate = [20, 30]
# Modify the color/transparency for the SolidFill layer
symLvl2 = cim_lyr.Renderer.Symbol.Symbol.SymbolLayers[1]
symLvl2.Color.Values = [140, 70, 20, 20]
# Push the changes back to the layer object
lyr.setDefinition(cim_lyr)
I think the documentation was written before finalization of ArcGIS Pro 2.4, where this functionality was introduced for the first time, because it seems to contain capitalization errors, and is missing a key line that I picked up by watching a
YouTube video from Esri's 2019 Developer Summit.
This code should work correctly:
symLvl1 = cim_lyr.renderer.symbol.symbol.symbolLayers[0]
symLvl1.color.values = [250, 250, 40, 50]
symLvl1.width = 8
symLvl1.effects = [arcpy.cim.CIMGeometricEffectDashes()]
ef1 = symLvl1.effects[0] #Note, deeper indentation
ef1.dashTemplate = [20, 30]
symLvl2 = cim_lyr.renderer.symbol.symbol.symbolLayers[1]
symLvl2.color.values = [140, 70, 20, 20]
The missing line (which I added in the above) is:
Is `arcpy.cim` an undocumented ArcPy module, function or class, and to learn about it, is reading the
ArcGIS.Core.CIM Namespace .NET SDK API Reference the only way?
