Hello.I'm trying to use the UseAcceleratedDisplay property and no matter in what form I use it (either as a property in the esri:Map object or as an object on it's on by puting my layers in <AcceleratedDisplayLayers></AcceleratedDisplayLayers>) it crashes my application.Here is an example of my XAML code:<esri:Map x:Name="MyMap" esri:Editor.SnapDistance="0" WrapAround="True" Margin="1,1,1,0" Height="{Binding Path=LocalSubLayerList}"
Background="White" MinimumResolution="0.001" MaximumResolution="1000" Style="{StaticResource MyMapStyle}"
MouseEnter="Map_MouseEnter" MouseLeave="Map_MouseLeave" MouseClick="QueryPoint_MouseClick" IsEnabled="False" IsLogoVisible="False" AllowDrop="True"
UseAcceleratedDisplay="True">
<esri:Map.Layers>
<esri:LayerCollection>
<esri:ArcGISLocalDynamicMapServiceLayer ID="Layers" x:Name="MXD1" DisableClientCaching="True" EnableDynamicLayers="True"
Initialized="ArcGISLocalDynamicMapServiceLayer_Initialized"/>
<esri:GraphicsLayer ID="SelectGraphic" RendererTakesPrecedence="True" ShowLegend="False"/>
<esri:GraphicsLayer ID="AreaGraphic" RendererTakesPrecedence="True" ShowLegend="False"/>
<esri:GraphicsLayer ID="DistanceGraphic" RendererTakesPrecedence="True" ShowLegend="False"/>
</esri:LayerCollection>
</esri:Map.Layers>
</esri:Map>
A note: in the MPK I use, I load both my layers and my rasters, meaning I don't use TPK for loading my rasters. The reason for this is that when I used TPK and MPK seperately, for some reason the GraphicLayers didn't appear in the application.Any ideas?
