I am trying to use the Try Except statement and I was wondering if I set it up correctly because I get an error when I run the script. I'm not sure if the error is due to the try Except or bad scripting on my part.
The script checks for a connection to NEO_1. If the connection exists then it checks all the versions name. This is where I seem to get an error. Since the user already exists the break should stop the script before prompting an error?
Empty Workspace Cache
Done
Connections Exists: NEO_1
Searching for User Credentials..
Windows Credentials: EGAS\jnmiller
Checking SDE for existing Credentials..
Executing: CreateVersion "Database Connections\NEO_1.sde" sde.DEFAULT jnmiller PROTECTED
Start Time: Wed Feb 21 11:38:41 2018
ERROR 001148: Cannot create a version with the specified name.
Version already exists [jnmiller][STATE_ID = 99689]
Failed to execute (CreateVersion).
Failed at Wed Feb 21 11:38:42 2018 (Elapsed Time: 0.72 seconds)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
# Name: SDE_CreateVersion
# Description: Creates a new SDE version
import arcpy, time, smtplib, os
from arcpy import env
arcpy.env.workspace = "Database Connections/NEO_1.sde"
connection = arcpy.env.workspace
# Set local variables
sdeConnection = "Database Connections\NEO_1.sde"
parentVersion = "sde.DEFAULT"
versionName = os.environ.get( "USERNAME" )
fullPath = os.path.join("Windows Credentials: EGAS", versionName)
userVersion = os.path.join("Version Currently Exists: ",versionName)
createVersion = os.path.join("Version Created: ",versionName)
# Clear Workspace Cache
print("Empty Workspace Cache")
arcpy.ClearWorkspaceCache_management()
print("Done")
# Database Connection: NEO_1 = True
if arcpy.Exists(connection):
versionFound = False
try:
for version in arcpy.da.ListVersions(sdeConnection):
if version.name.split(".")[0] == versionName:
print(userVersion)
versionFound = True
break
# Execute CreateVersion
if not versionFound:
arcpy.CreateVersion_management(sdeConnection, parentVersion, versionName, "PROTECTED")
print(createVersion)
except arcpy.ExecuteError:
print(arcpy.GetMessages())
# Database Connection: NEO_1 = False
if not arcpy.Exists(connection):
print("Creating Database Connection: NEO_1")
arcpy.CreateDatabaseConnection_management(out_folder_path="Database Connections",
out_name="NEO_1.sde",
database_platform="SQL_SERVER",
instance="lan-svr-sql",
account_authentication="OPERATING_SYSTEM_AUTH",
database="NEO_1",
version_type="TRANSACTIONAL",
version="sde.DEFAULT")
arcpy.env.workspace = r"Database Connections\NEO_1.sde"
try:
print(existingVersion)
versionFound = True
break
#Execute CreateVersion
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
