Hello all,
Track widget simulation | ArcGIS API for JavaScript 4.14
I am trying to write some code using the Track Widget functionality demonstrated in the Esri Sample above. It specifically uses an external js library to force a custom location for its geolocation service instead of the current location of the browser. I want to use this method to modify the sample code shown in the Track Widget simulation, however when I try to run the code outside of the sandbox, i keep getting an error in loading the custom js library. Error message listed below:
| Error in my browser's console: |
geolocate.js:1 Failed to load resource: net::ERR_FILE_NOT_FOUND |
dojo.js:24 Error: scriptError: //2gis.github.io/mock-geolocation/dist/geolocate.js at q (dojo.js:5) at HTMLScriptElement.<anonymous> (dojo.js:23) |
Running the demo in the sandbox works fine, but when I try to run it outside in a standalone html file, the demo code does not work at all.
Weird thing is that I can open the link to the file that the mock-geolocation file is stored in, but for some reason the script in the html cannot. Also even when I give it a modified url to the RAW location of the js library on GitHub, it then fails to recognize the functions of the library.
Please help! Thank you
Jaydeep
