I'm getting a TaskCanceledException when I shut down my application. Stack trace below. I'm using 100.2.1 on Windows 10 x64. In my current scenario I have one basemap layer (local tpk file) and a few graphics overlays that contain graphics that are being updated at ~1Hz.
Thoughts on what may be causing this or how to prevent it? Thank you.
at System<SPAN class="punctuation token">.</SPAN>Runtime<SPAN class="punctuation token">.</SPAN>CompilerServices<SPAN class="punctuation token">.</SPAN>TaskAwaiter<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ThrowForNonSuccess</SPAN><SPAN class="punctuation token">(</SPAN>Task task<SPAN class="punctuation token">)</SPAN>
at System<SPAN class="punctuation token">.</SPAN>Runtime<SPAN class="punctuation token">.</SPAN>CompilerServices<SPAN class="punctuation token">.</SPAN>TaskAwaiter<SPAN class="punctuation token">.</SPAN><SPAN class="token function">HandleNonSuccessAndDebuggerNotification</SPAN><SPAN class="punctuation token">(</SPAN>Task task<SPAN class="punctuation token">)</SPAN>
at System<SPAN class="punctuation token">.</SPAN>Windows<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>DispatcherOperation<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Wait</SPAN><SPAN class="punctuation token">(</SPAN>TimeSpan timeout<SPAN class="punctuation token">)</SPAN>
at System<SPAN class="punctuation token">.</SPAN>Windows<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Dispatcher<SPAN class="punctuation token">.</SPAN><SPAN class="token function">InvokeImpl</SPAN><SPAN class="punctuation token">(</SPAN>DispatcherOperation operation<SPAN class="punctuation token">,</SPAN> CancellationToken cancellationToken<SPAN class="punctuation token">,</SPAN> TimeSpan timeout<SPAN class="punctuation token">)</SPAN>
at System<SPAN class="punctuation token">.</SPAN>Windows<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Dispatcher<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Invoke</SPAN><SPAN class="punctuation token">(</SPAN>Action callback<SPAN class="punctuation token">,</SPAN> DispatcherPriority priority<SPAN class="punctuation token">,</SPAN> CancellationToken cancellationToken<SPAN class="punctuation token">,</SPAN> TimeSpan timeout<SPAN class="punctuation token">)</SPAN>
at System<SPAN class="punctuation token">.</SPAN>Windows<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Dispatcher<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Invoke</SPAN><SPAN class="punctuation token">(</SPAN>Action callback<SPAN class="punctuation token">)</SPAN>
at Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime<SPAN class="punctuation token">.</SPAN>UI<SPAN class="punctuation token">.</SPAN>Controls<SPAN class="punctuation token">.</SPAN>GeoView<SPAN class="punctuation token">.</SPAN>RuntimeCoreNet<SPAN class="punctuation token">.</SPAN>ICoreCallback_GeoView_LockSurface<SPAN class="punctuation token">.</SPAN><SPAN class="token function">UnlockSurfaceRequested</SPAN><SPAN class="punctuation token">(</SPAN>Boolean wasResized<SPAN class="punctuation token">)</SPAN>
at RuntimeCoreNet<SPAN class="punctuation token">.</SPAN>CoreDxDevice<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OnPrivateCoreGeoView_UnlockSurfaceRequested</SPAN><SPAN class="punctuation token">(</SPAN>Boolean wasResized<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
