So when you create an annotation layer that you can design and in it has an attribute field called "Status", which tells you to placed or unplaced the annotation to be display it or not to display it.
My question to you. How do you turn off the symbology you set it up as a Layer whether they be a polygon, point, or polyline and you assign a new field column "Status" and add it Annotation Status as a Coded value domian.
I just did mine on my Campgound Labels point layer. When I select a point to tell that one to unplaced and it is still showing the icon ?
I do not want to delete the point, because I might need it later .
