Hey everybody,
In my drawing app, I want to add the possibility of buffering a point. I got it to work, but I have one issue.
When I run it the first time everything goes ok. User checks the buffer checkbox, types in a buffer distance, selects the point button, clicks on the map and the buffer gets added to the map.
When I run it a 2nd time, it looks like it works again like it is supposed to, but this time two identical buffer get added. When I do it a third time 3 identical buffers get added and so on.
It seems that geometryService.on("buffer-complete") runs as often as I used the buffer before.
Here is the code snipped that is responsible for adding the buffer:
function addToMap(evt) {
Uni();
if ( evt === undefined){
console.log("undefined");
} else {
toolbar.deactivate();
var Testcolor = cp.value;
if (Testcolor == ""){
newColor = newColor;
} else {
docolor();
switch (evt.geometry.type) {
case "point":
case "multipoint":
symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, myNumber,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color(newColor), 1),
new Color(newColor));
break;
case "polyline":
symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color(newColor), myNumber)
break;
default:
symbol = new SimpleFillSymbol(symbolfill, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color(newColor), myNumber), new Color(newColor));
break;
graphic = new Graphic(evt.geometry, symbol);
if (dijit.byId("BufferCheckBox").checked && evt.geometry.type == "point" ){
params = new BufferParameters();
params.geometries = [ evt.geometry ];
params.distances = [ dom.byId('BufferText').value ];
params.geodesic = true;
params.bufferSpatialReference = new SpatialReference({wkid: 102100});
params.outSpatialReference = map.spatialReference;
params.unit = Unit_Line;
geometryService.buffer(params);
geometryService.on("buffer-complete", function(evt) {
var Buffsymbol = new SimpleFillSymbol("none", new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color(newColor), 2), new Color(newColor));
Buffgraphic = new Graphic(evt.geometries[0], Buffsymbol);
map.graphics.add(Buffgraphic);
var operation2 = new CustomOperation.Add({
graphicsLayer: map.graphics,
addedGraphic: Buffgraphic
undoManager.add(operation2);
Any help is appreciated!
Tim
