I want to give users flexibility to add basemap layer after their dynamic service layer is loaded on the map. See following example, I have highlighted code and what works/doesn't work.
I guess basemap must be added as first layer only. basemap's layer id will be always layer0? Is there any workaround if the basemap is not added as a first layer and want to add it after the map is loaded with dynamic service layer?
<!DOCTYPE html>
<html>
<head>
<title>Feature Layer Only Map</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
html, body, #map {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
</style>
<script src="http://js.arcgis.com/3.13/"></script>
<script>
require([
"dojo/dom-construct",
"esri/map",
"esri/layers/FeatureLayer",
"esri/geometry/Extent",
"esri/InfoTemplate",
"dojo/domReady!"
], function(
domConstruct,
Map,
FeatureLayer,
Extent,
InfoTemplate
var bounds = new Extent({
"xmin":-16045622,
"ymin":-811556,
"xmax":7297718,
"ymax":11142818,
"spatialReference":{"wkid":102100}
var map = new Map("map", {
extent: bounds
var url = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/WorldTimeZones/MapServer/2";
var template = new InfoTemplate("World Regions", "Region: ${REGION}");
var fl = new FeatureLayer(url, {
infoTemplate: template
//map.setBasemap('streets'); //it works here
map.addLayer(fl);
map.setBasemap('streets'); //it doesn't work here
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
