I have a geprocessing service that returns JSON that I am attempting to put into a datagrid.
Snippet of JSON from GP service:
Here is the relevant code:
map.on("load", initSelectionToolbar);
registry.byId("point").on("click", function() {
activateTool(this.id);
function initSelectionToolbar() {
map.graphics.clear();
selectionToolbar = new Draw(map);
selectionToolbar.on("draw-end", function(e) {
selectionToolbar.deactivate();
var symbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE,
16,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([89, 95, 35]), 2
new Color([130, 159, 83, 0.40])
var graphic = new Graphic(e.geometry, symbol);
map.graphics.add(graphic);
map.infoWindow.hide();
function activateTool(tool) {
// The draw.activate expects a string like "polygon" or "freehand_polygon".
selectionToolbar.activate(tool);
registry.byId("searchSPs").on("click", searchSPs);
function searchSPs() {
var geom = map.graphics
var dist = dom.byId("distance").value
var distUnit = dom.byId("distanceUnits").value
var params = {
pointX: geom.graphics[0].geometry.x,
pointY: geom.graphics[0].geometry.y,
buffer: dist,
unitType: distUnit
gp.submitJob(params, completeCallback, statusCallback);
function statusCallback(jobInfo) {
console.log(jobInfo.jobStatus);
function completeCallback(jobInfo) {
var id = jobInfo.jobId
var data = gp.getResultData.id
var stuff = gp.getResultData(id, "output", displaySPs);
function displaySPs(outputFile) {
var searchS = outputFile.value.SPs;
searchS.sort(function(a, b) {
return a.Distance - b.Distance
//tried this, does not work.
// var items = arrayUtils.map(searchS, function(result) {
// return result;
var items = []
items = searchS;
var data = {
idProperty: "output", //This field needs to have unique values
label: "StationID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
items: items
store = new ItemFileReadStore({
//either way behaves the same way.
//data: {identifier: 'StationID', items: items}
data: data
var grid = registry.byId("grid");
//identifier present in the store.
grid.store = store
//no identifier in the store, even though it is present.
//window.grid.set("store", items);
//this does not work.
//grid.setStore(store);
};and the HTML:
<div id="rightPane" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
<button id="point" data-dojo-type="dijit/form/Button">Select Point</button>
<br> Search Distance:
<input type="text" id="distance" size="5" value="200" />
<select data-dojo-type="dijit/form/Select" id="distanceUnits">
<option value="feet">Feet</option>
<option value="meters">Meters</option>
</select>
<br>
<button id="searchSPs" data-dojo-type="dijit/form/Button" value="searchSPs">Search Splice Points</button>
<br>
<table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" style="width:100%;height:100%; data-dojo-props=" rowsPerPage: '10', rowSelector: '20px' " class="roundedCorners shadow ">
<thead>
<tr>
<th field="StationID ">Station ID</th>
<th field="Subtype ">Subtype</th>
<th field="Distance ">Distance (meters)</th>
</tr>
</thead>
</table>
</div>
When I check the datastore in the console here is what I see
No matter what I do though the datagrid is not updated with the values I am looking for. Any thoughts?
Jim
