I'm attempting to connect to the map's onLoad event:var map; require(["esri/map", "esri/SpatialReference", "esri/geometry/Extent", "dojo/_base/connect", "app/populate", "dojo/ready"], function(Map, SpatialReference, Extent, connect, populate, ready) { ready(function() { var initialExtent = new Extent({ xmax: -11241653.995873693, xmin: -13198441.919973679, ymax: 5178320.359930991, ymin: 4453085.835561435, "spatialReference": { "wkid": 102100 }}); map = new Map("mapDiv", { extent: initialExtent, basemap: "streets" }); connect(map, "onLoad", function() { populate.addPoints(); }); }); }); }No matter what, I keep getting a JS error: Uncaught TypeError: Object is not a function.
I've tried replacing the call to populate.addPoints() with a simple console.log, and still, it errors on "connect". That's a pretty basic Dojo thing, so I'm confused about where the problem is. The examples page shows something nearly identical.
