I populate my form based on a map click event which had been working, but no longer is. I have uploaded the current code on Github at: csergent45/streetSigns · GitHub
If you would like to see how to re-create the error that I am running into, I have a screen recording explaining how:
https://www.youtube.com/watch?v=7ZUA1FhiCtE
The error that I receive is: Uncaught TypeError: Cannot read property 'defaultPrevented' of undefined from: http://rawgit.com/xsokev/Dojo-Bootstrap/master/Modal.js
The code that populates or should populate my for input boxes is the following:
/* Get support information on click */
var supportId, type, address;
app.supportLayer.on("click", function (evt) {
// declare rest endpoint values
supportId = evt.graphic.attributes.SUPPORTID;
type = evt.graphic.attributes.TYPE;
address = evt.graphic.attributes.ADDRESS;
app.attributesModal.modal("show");
document.getElementById("supportForm").reset();
/* Enter your domain item and then the element to populate */
populateSelect("TYPE", "type", "support");
populateSelect("SIZE_", "size", "support");
populateSelect("MATERIAL", "material", "support");
populateSelect("BASE", "base", "support");
populateSelect("RATING", "rating", "support");
// Show supports form for updating
document.getElementById("address").value = address;
document.getElementById("supportId").value = supportId;
document.getElementById("type").value = type;
console.log(supportId);
console.log(type);
console.log(address);
