Hi everyone,
I am working through the Objected Oriented tutorial found here: Creating an oriented imagery catalog—Imagery Workflows | Documentation
When I get to step 6, "Analyze your OIC to see if you need to optimize or fix anything ... using the Analyze Oriented Imagery Catalog GP tool", I receive the following error:
- The following mandatory field(s) have no values in the feature class for one or more rows.
- These field(s) do not have a default value set in the OIC properties file either.
CamRoll - Please make sure to fill values in the rows using 'Calculate Field' or the OIC Properties GP Tool.
I did a few things to attempt to address this.
- I re-ran the Properties tool and re-ran with the CamRoll value at 0. (It was already that). Then recreated the coverage tool and map. When re-running the Analyze tool, I did not get the error mentioned above. I published the OIC and created the web app, but I can only toggle on the Coverage Map, not the Image Exposure Points , Current Coverage, or Additional Coverage.
- I checked my ArcGIS Pro version and noticed that an update was available. I installed the update and repeated the process, however get the same result.
I am now using ArcGIS Pro 2.6.2, publishing directly to AGOL, and am using the Oriented Imagery Management Tools last updated on September 20th https://www.arcgis.com/home/item.html?id=36ee0bbedca64a5a8b68d7c69ab51728
Has anyone come across this?
Thanks!
Alyssa
