I am trying to join three tables from the same FGDB via Make Query table.
Validation in Model Builder shows no errors. If I run my tool from Model Builder the following error messages are displayed:
ERROR 999999: Error executing function.
An expected Field was not found or could not be retrieved properly. [S_LX_Abzugsbefreiungen_Query]
An expected Field was not found or could not be retrieved properly. [OID]
Failed to execute (Make Query Table).
What's wrong? S_LX_Abzugsbefreiungen_Query is the name of the table that should be created.
The error persists even if I remove the SQL query, so the reason cannot be a syntax error in th query.
BTW: I'm using ArcGIS 10.0 SP5.
Thanks for any help
Andreas
