While creating Vector Tile package creation using the selected layer extent, the output vtpk does not have the selected extent.Please review my code and correct it.
project<SPAN class="operator token">=</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"e:\projects\waldo\CREATE_VTPK_PACKAGE.aprx"</SPAN><SPAN class="punctuation token">)</SPAN>
map <SPAN class="operator token">=</SPAN> project<SPAN class="punctuation token">.</SPAN>listMaps<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"LANDBASE"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
layer <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>listLayers<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"PLAT GRID"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>analysis<SPAN class="punctuation token">.</SPAN>Select<SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"E:\Projects\Waldo\CREATE_VTPK_PACKAGE.gdb\WC_ID_1555"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"WC_ID =1555"</SPAN><SPAN class="punctuation token">)</SPAN>
lyt <SPAN class="operator token">=</SPAN> project<SPAN class="punctuation token">.</SPAN>listLayouts<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"LBELayer_WALDO"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
mf <SPAN class="operator token">=</SPAN> lyt<SPAN class="punctuation token">.</SPAN>listElements<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MAPFRAME_ELEMENT'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Layers Map Frame"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
ext <SPAN class="operator token">=</SPAN> mf<SPAN class="punctuation token">.</SPAN>camera<SPAN class="punctuation token">.</SPAN>getExtent<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
mf<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>addDataFromPath<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"E:\Projects\Waldo\CREATE_VTPK_PACKAGE.gdb\WC_ID_1555"</SPAN><SPAN class="punctuation token">)</SPAN>
WC_ID <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>listLayers<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
mf<SPAN class="punctuation token">.</SPAN>camera<SPAN class="punctuation token">.</SPAN>setExtent<SPAN class="punctuation token">(</SPAN>mf<SPAN class="punctuation token">.</SPAN>getLayerExtent<SPAN class="punctuation token">(</SPAN>WC_ID<SPAN class="punctuation token">,</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
map<SPAN class="punctuation token">.</SPAN>defaultCamera<SPAN class="punctuation token">.</SPAN>setExtent<SPAN class="punctuation token">(</SPAN>mf<SPAN class="punctuation token">.</SPAN>getLayerExtent<SPAN class="punctuation token">(</SPAN>WC_ID<SPAN class="punctuation token">,</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
layers<SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>listLayers<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> l <SPAN class="keyword token">in</SPAN> layers<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> l<SPAN class="punctuation token">.</SPAN>name<SPAN class="operator token">==</SPAN><SPAN class="string token">"WC_ID_1555"</SPAN><SPAN class="punctuation token">:</SPAN>
map<SPAN class="punctuation token">.</SPAN>removeLayer<SPAN class="punctuation token">(</SPAN>l<SPAN class="punctuation token">)</SPAN>
project<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>CreateVectorTileIndex<SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"E:\Projects\Waldo\CREATE_VTPK_PACKAGE.gdb\IDX_1555"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"EXISTING"</SPAN><SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"C:\Users\AppData\Local\ESRI\Geoprocessing\VTTS_4326_GCS_WGS_1984.xml"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10000</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>CreateVectorTilePackage<SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"E://Projects//Waldo//MobileMapPackages//VTPK_FILES//1_1555"</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.vtpk'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"EXISTING"</SPAN><SPAN class="punctuation token">,</SPAN>Tiling_Schema<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"INDEXED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">295829355.454566</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"E:\Projects\Waldo\CREATE_VTPK_PACKAGE.gdb\IDX_1555"</SPAN><SPAN class="punctuation token">)</SPAN>
project<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
