Just noticed that the BaseMapToggle widget has properties renamed... found this thanks to the helpful error messages when using Typescript. Used to be for 4.10 as follows...
<SPAN class="keyword token">let</SPAN> basemapToggle <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">BasemapToggle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
secondmap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"satellite"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Now, it's
nextBasemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"satellite"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Not a big deal but I didn't see that in the Release Notes. Is there a place to note observations like this that may be missing from documentation?
