I am trying to add this search function to a map:
require([
"esri/map",
"esri/dijit/Search",
"dojo/domReady!"
], function (Map, Search) {
var map = new Map("map", {
basemap: "gray",
center: [-120.435, 46.159], // lon, lat
zoom: 7
var s = new Search({
map: map
}, "search");
s.startup();
Here is the full js:
var map;
require([
"esri/map",
"esri/arcgis/utils",
"esri/dijit/Legend",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/ArcGISDynamicMapServiceLayer",
"dojo/dom",
"dojo/dom-construct",
"dojo/parser",
"dojo/_base/array",
"dijit/form/CheckBox",
"esri/graphic",
"esri/symbols/SimpleMarkerSymbol",
"esri/geometry/screenUtils",
"dojo/query",
"dojo/_base/Color",
"dijit/layout/AccordionContainer",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"
function (
Map, Search, utils, Legend, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
dom, domConstruct,
parser, arrayUtils, CheckBox, Graphic, SimpleMarkerSymbol, screenUtils, query, Color
parser.parse();
var legendLayers = [];
map: map
}, "search");
s.startup();
basemap: "topo",
center: [10, 23],
zoom: 2
// duplicate this for each layer - use dynamic layer service for those types
var LADALandUse = new ArcGISTiledMapServiceLayer("http://tiles.arcgis.com/tiles/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/LADA_Land_Use_Systems/MapServer", {
legendLayers.push({ layer: LADALandUse, title: 'Land Use' });
// to here
var WWFTerEco = new ArcGISTiledMapServiceLayer("http://tiles.arcgis.com/tiles/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/LADA_Land_Use_Systems/MapServer", {
legendLayers.push({ layer: WWFTerEco, title: 'WWF Terrestrial Ecoregion' });
var climateLayer = new ArcGISTiledMapServiceLayer("http://tiles.arcgis.com/tiles/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/LADA_Land_Use_Systems/MapServer", {
map.on('layers-add-result', function () {
var legend = new Legend({
map: map,
layerInfos: legendLayers
}, "legendDiv");
legend.startup();
legendLayers.push({ layer: climateLayer, title: "Climate" });
map.addLayers([ climateLayer, LADALandUse, WWFTerEco ]); /*add the layer var here*/
//add check boxes
arrayUtils.forEach(legendLayers, function (layer) {
var layerName = layer.title;
var checkBox = new CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible
checkBox.on("change", function () {
var targetLayer = map.getLayer(this.value);
targetLayer.setVisibility(!targetLayer.visible);
this.checked = targetLayer.visible;
//add the check box and label to the toc
domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after");
var checkLabel = domConstruct.create('label', {
'for': checkBox.name,
innerHTML: layerName
}, checkBox.domNode, "after");
domConstruct.place("<br />", checkLabel, "after");
Any guidance is greatly appreciated.
