I have no idea why I can run this tool from tool dialogue but not from the following script?Error Message: Failed to execute. Parameters are not valid. ERROR 000368: Invalid input data.Failed to execute (SelectLayerByLocation).import arcpy import os from arcpy import env env.overwriteOutput = 1 ''' lines = arcpy.GetParameterAsText(0) results = arcpy.GetParameterAsText(1) ''' lines = 'G:/Xcel/Route Tool/Southwest/Scratch.gdb/lines_clip' results = 'G:/Xcel/Route Tool/Southwest/Results.gdb' line_string = '"' + "'" + lines + "'" + " #" + '"' env.workspace = results def main(): points = results + '\\pts' # Process: Find all stream crossings (points) #arcpy.Intersect_analysis(lines,'G:\Xcel\Route Tool\Southwest\Results.gdb\pts',"ONLY_FID","#","POINT") in_features = "'" + lines + "'" + " #" arcpy.Intersect_analysis(in_features,\ out_feature_class="G:/Xcel/Route Tool/Southwest/Scratch.gdb/lines_clip_Intersect",\ join_attributes="ONLY_FID",cluster_tolerance="#",output_type="POINT") # Adds x and y field to points pts_geometry = arcpy.AddXY_management("G:/Xcel/Route Tool/Southwest/Scratch.gdb/lines_clip_Intersect") # Dissolves duplicate points arcpy.Dissolve_management(pts_geometry,"pts_dissolve","POINT_X;POINT_Y","#","SINGLE_PART","DISSOLVE_LINES") # Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script # The following inputs are layers or table views: "pts_dissolve", "LCP_A" arcpy.SelectLayerByLocation_management("pts_dissolve","INTERSECT","LCP_A","400 Feet","ADD_TO_SELECTION")
