I wanted to know if there is a way to use require with a js generated by webpack using the html-webpack-plugin in hash mode.
Right now i require my file like:
<SPAN class="operator token"><</SPAN>script type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/javascript"</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"js/app.js"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>But the html generated by webpack plugin is giving me this:
<SPAN class="operator token"><</SPAN>script type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/javascript"</SPAN> src<SPAN class="operator token">=</SPAN><SPAN class="string token">"/app.js?add154b89f3e48308da7"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
So, how i do it if my file has a hash integrated?
I tried already this:
<SPAN class="operator token"><</SPAN>script type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/javascript"</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"js/app.js?add154b89f3e48308da7"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>But it didnt work.
Thanks for the help.
