Can you please let me know if there is a way to bind a CSS class `.marker` to an ArcGIS `SimpleMarkerSymbol` in a graphic layer?
I have a `SimpleMarkerSymbol` called `schoolMarker` which I am styling it using ESRI's options but I need to add more CSS styles like `.marker`
<SPAN class="keyword token">var</SPAN> schoolMarker <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
schoolMarker<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setStyle</SPAN><SPAN class="punctuation token">(</SPAN>SimpleMarkerSymbol<SPAN class="punctuation token">.</SPAN>STYLE_CIRCLE<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
schoolMarker<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">30</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
schoolMarker<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOutline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
schoolMarker<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">116</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Here is the CSS class:
<SPAN class="selector token">.marker</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">stroke-linecap</SPAN><SPAN class="punctuation token">:</SPAN> round<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">stroke-linejoin</SPAN><SPAN class="punctuation token">:</SPAN> round<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">stroke-opacity</SPAN><SPAN class="punctuation token">:</SPAN> 1.0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">fill-opacity</SPAN><SPAN class="punctuation token">:</SPAN> 1.0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">background-color</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token function">rgb</SPAN><SPAN class="punctuation token">(</SPAN>0, 89, 190<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">stroke</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token function">rgb</SPAN><SPAN class="punctuation token">(</SPAN>0, 89, 190<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">fill</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token function">rgb</SPAN><SPAN class="punctuation token">(</SPAN>0, 89, 190<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">fill-opacity</SPAN><SPAN class="punctuation token">:</SPAN> 1<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">stroke-width</SPAN><SPAN class="punctuation token">:</SPAN> 70pt<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">stroke-opacity</SPAN><SPAN class="punctuation token">:</SPAN> 1<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0.12<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
