Hi,I am creating a suite of Add-Ins and this on backs up a selected layer. It works fine with a FileGDB but I get an COM Exception with an SDE. I am using an ArcEditor License and the code will create and delete the feature class in the SDE but it won't append. Here is the exception.[ATTACH=CONFIG]17776[/ATTACH] public static IWorkspace FileGdbWorkspaceFromPath(String path)
Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.FileGDBWorkspaceFactory");
IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);
return workspaceFactory.OpenFromFile(path, 0);
public IWorkspace WorkgroupArcSdeWorkspaceFromString(string connectionString)
try
Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory");
IWorkspaceFactory2 workspaceFactory2 = (IWorkspaceFactory2)Activator.CreateInstance(factoryType);
return workspaceFactory2.OpenFromString(connectionString, 0);
catch (Exception exc)
MessageBox.Show(Convert.ToString(exc));
return null;
public IFeatureClass GetFeatureClassOfSelectedFeatureLayer(IFeatureLayer featureLayer)
IFeatureClass featureClass = featureLayer.FeatureClass;
return featureClass;
protected override void OnClick()
//IWorkspace workSpace = FileGdbWorkspaceFromPath(@G:\PROJECTS\SCHOOL_SAFETY_MAPPING_APPLICATION_20120606\DATA\SchoolSafety.gdb);
string connectionString = "SERVER=dotdevgissql01;DATABASE=GISAPP_SCHOOLSAFETY;INSTANCE=sde:sqlserver:dotdevgissql01;AUTHENTICATION_MODE=DBMS;USER=...;PASSWORD=...;VERSION=dbo.DEFAULT";
IWorkspace workSpace = WorkgroupArcSdeWorkspaceFromString(connectionString);
CreateFeatureClass(workSpace, "SelectedLayerBU");
public void CreateFeatureClass(IWorkspace workspace, String featureClassName)
IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace;
IWorkspace2 pWorkspace2 = workspace as IWorkspace2;
////Delete the Feature Class if it already exists////
if (pWorkspace2.get_NameExists(ESRI.ArcGIS.Geodatabase.esriDatasetType.esriDTFeatureClass, "SelectedLayerBU"))
FeatureClass featureC = (FeatureClass)featureWorkspace.OpenFeatureClass("SelectedLayerBU");
IDataset dataSet;
//ISchemaLock schemaLock = (ISchemaLock)featureC;
dataSet = featureC;
dataSet.Delete();
//schemaLock.ChangeSchemaLock(esriSchemaLock.esriSharedSchemaLock);
IFeatureClass featureSelected = GetFeatureClassOfSelectedFeatureLayer((IFeatureLayer)ArcMap.Document.SelectedLayer);
try
featureWorkspace.CreateFeatureClass("SelectedLayerBU", featureSelected.Fields, featureSelected.CLSID, featureSelected.EXTCLSID, featureSelected.FeatureType, featureSelected.ShapeFieldName, null);
Geoprocessor gp = new Geoprocessor();
FeatureClass featureClassNew = (FeatureClass)featureWorkspace.OpenFeatureClass("SelectedLayerBU");
IDataset dataSet2;
dataSet2 = featureClassNew;
gp.SetEnvironmentValue("workspace", connectionString);
//gp.SetEnvironmentValue("workspace", @G:\PROJECTS\SCHOOL_SAFETY_MAPPING_APPLICATION_20120606\DATA\SchoolSafety.gdb);
Append append = new Append(); //this tool uploads the feature class
append.inputs = featureSelected;
append.target = dataSet2;
gp.AddOutputsToMap = false;
gp.Execute(append, null);
Thanks for any insight,Robbie
