When i zoom out all the way where I can see the entire world, I get two different images from PrintTask vs print dijit.PrintTask gives me an oval (globe-like) image, while print dojit gives me a flat image. I am trying to acquire a flat image using printtask. Any ideas? Here is what I have:-----<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="test.aspx.cs" Inherits="TestWebApp.test" %>
<!DOCTYPE html>
<!doctype html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Feature Layer - display results as an InfoWindow onHover</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
<style>
html, body, #mapDiv {
padding:0;
margin:0;
height:100%;
#mapDiv {
position: relative;
</style>
<script src="http://js.arcgis.com/3.8/"></script>
<script>
var map, dialog;
require([
"esri/map", "esri/tasks/PrintTemplate", "esri/tasks/PrintParameters", "esri/tasks/PrintTask", "esri/dijit/Print"
], function (
Map, PrintTemplate, PrintParameters, PrintTask, Print
map = new Map("mapDiv", {
basemap: "streets",
center: [0, 33.646],
zoom: 2,
slider: false
esri.config.defaults.io.proxyUrl = "/proxy.ashx";
esri.config.defaults.io.alwaysUseProxy = false;
document.getElementById("printBtn").onclick = function () {
var printTask = new esri.tasks.PrintTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task");
var printParams = new esri.tasks.PrintParameters();
var template = new esri.tasks.PrintTemplate();
template.layout = "MAP_ONLY"; //Tabloid ANSI B Landscape
template.format = "JPG";
printParams.map = map;
printParams.outSpatialReference = new esri.SpatialReference({ wkid: 26917 });
printParams.template = template;
printTask.execute(printParams, function (mapUrl) {
console.log('The url to the print image is : ' + mapUrl.url);
}, function (err) {
alert('error');
var printer = new Print({
map: map,
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"
}, document.getElementById("printBtn2"));
printer.startup();
</script>
</head>
<body class="tundra">
<div id="mapDiv">
</div>
<div id ="printBtn" style="position: absolute; left: 0; top: 0;">Print</div>
<div id ="printBtn2" style="position: absolute; left: 0; top: 20px;">Print2</div>
</body>
</html>
