I have a program that checks a raster catalog against view extent, copies any files to the project folder, and then the final step is to either:
1. Navigate to the project folder where the raster files are saved, if ArcCatalog is open.
or
2. Open ArcCatalog, then perform step 1.
This worked perfectly fine in ArcGIS 10.1, but after having upgraded to 10.4.1, this no longer works.
I'm using .NET, the code is below. I'm curious why this no longer works (serious application error crash).
' Application Running Object Table to access applications.
Dim pAppROT As IAppROT
pAppROT = New AppROT
' Cycle until ArcCatalog is found.
Dim pGxApplication As IGxApplication
Dim bCatalog As Boolean
Dim iAppCount As Integer
pGxApplication = Nothing
' Get the total number of ESRI "Arc" processes running.
iAppCount = pAppROT.Count
If iAppCount > 0 Then
Dim i As Integer
For i = 0 To iAppCount - 1
If pAppROT.Item(i).Name <> "ArcCatalog" Then
bCatalog = False
Else
bCatalog = True
Exit For
End If
Next i
' If catalog doesn't exist, launch one. Go to destination folder.
If Not bCatalog Then
Dim iCount As Integer
iCount = 1
Shell("C:\Program Files (x86)\ArcGIS\Desktop10.4\bin\ArcCatalog.exe", AppWinStyle.NormalFocus)
Do While pAppROT.Count = iAppCount
Thread.Sleep(500)
Loop
For i = 0 To pAppROT.Count - 1
If pAppROT.Item(i).Name = "ArcCatalog" Then
pGxApplication = pAppROT.Item(i)
With pGxApplication
.Location = sImageryDestination
.Refresh(sImageryDestination)
End With
End If
Next i
Else
With pGxApplication
.Refresh("Y:\01_GISProject")
End With
End If
End If<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
