So I tried to add Print function on my arcgis map. It's doesn't work at all. So I tried to start new project and figure it out. It worked fine.
Back to my main project, I realized the errors is came from parser itself. When I comment the parser.parse(); the print function is work but a part of my function didn't work out.
I've tried to add this:
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> dojoConfig <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> parseOnLoad<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">async</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> tlmSiblingOfDojo<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
It doesn't work out.
Here is the print function:
parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
esriConfig<SPAN class="punctuation token">.</SPAN>defaults<SPAN class="punctuation token">.</SPAN>io<SPAN class="punctuation token">.</SPAN>corsEnabledServers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"1xx.1xx.xyz.xx2:6443"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"mapDiv"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// basemap: "satellite",</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"topo"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">118</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN>
sliderStyle<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"small"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
printUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F1xx.1xx.7x.2xx%3A6443%2Farcgis%2Frest%2Fservices%2FUtilities%2FPrintingTools%2FGPServer%2FExport%2520Web%2520Map%2520Task" target="_blank">https://1xx.1xx.7x.2xx:6443/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> printInfo <SPAN class="operator token">=</SPAN> <SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"url"</SPAN><SPAN class="punctuation token">:</SPAN> printUrl<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"content"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"f"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN> <SPAN class="punctuation token">}</SPAN>
printInfo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN>printUrl<SPAN class="punctuation token">,</SPAN>dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">,</SPAN>handlePrintInfo<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> handleError<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">handlePrintInfo</SPAN><SPAN class="punctuation token">(</SPAN>resp<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> layoutTemplate<SPAN class="punctuation token">,</SPAN> templateNames<SPAN class="punctuation token">,</SPAN> mapOnlyIndex<SPAN class="punctuation token">,</SPAN> templates<SPAN class="punctuation token">;</SPAN>
layoutTemplate <SPAN class="operator token">=</SPAN> arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">filter</SPAN><SPAN class="punctuation token">(</SPAN>resp<SPAN class="punctuation token">.</SPAN>parameters<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>param<SPAN class="punctuation token">,</SPAN> idx<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> param<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Layout_Template"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN> layoutTemplate<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">===</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"print service parameters name for templates must be \"Layout_Template\""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN>
templateNames <SPAN class="operator token">=</SPAN> layoutTemplate<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>choiceList<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// remove the MAP_ONLY template then add it to the end of the list of templates </SPAN>
mapOnlyIndex <SPAN class="operator token">=</SPAN> arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>templateNames<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MAP_ONLY"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN> mapOnlyIndex <SPAN class="operator token">></SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN> <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> mapOnly <SPAN class="operator token">=</SPAN> templateNames<SPAN class="punctuation token">.</SPAN><SPAN class="token function">splice</SPAN><SPAN class="punctuation token">(</SPAN>mapOnlyIndex<SPAN class="punctuation token">,</SPAN> mapOnlyIndex <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
templateNames<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>mapOnly<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create a print template for each choice</SPAN>
templates <SPAN class="operator token">=</SPAN> arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN>templateNames<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>ch<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> plate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PrintTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
plate<SPAN class="punctuation token">.</SPAN>layout <SPAN class="operator token">=</SPAN> plate<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> ch<SPAN class="punctuation token">;</SPAN>
plate<SPAN class="punctuation token">.</SPAN>format <SPAN class="operator token">=</SPAN> <SPAN class="string token">"PDF"</SPAN><SPAN class="punctuation token">;</SPAN>
plate<SPAN class="punctuation token">.</SPAN>layoutOptions <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"authorText"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Author."</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"copyrightText"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"<copyright info here>"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"legendLayers"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"titleText"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"A title"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"scalebarUnit"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Kilometers"</SPAN>
<SPAN class="keyword token">return</SPAN> plate<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create the print dijit</SPAN>
<SPAN class="keyword token">var</SPAN> printer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"templates"</SPAN><SPAN class="punctuation token">:</SPAN> templates<SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"print_map"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
printer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">handleError</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Something broke: "</SPAN><SPAN class="punctuation token">,</SPAN> err<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>How can I make the print function work out without removing parser.parse();? If I didn't use parser, all my function can't be loaded, and if I use parser, the json can't be sent to server service.
