Trying to use the Edit widget in a Web Map App built through Builder.
Data is a zipped shapefile of attributed polygons uploaded to ArcGIS Online from which a Feaure Service has been created.
I can configure the Pop Up box to include attributes - with alternative (Alias) names manually in the configuration box. Interrogating features - the popup displays correctly. (Pic 1)
When however I open the Edit Widget - this displays fields with the Attribute Field names defined in the Feature Service.
Using the "Configure Attributes" tool - I can rename the Alias fields - (and turn off fields I don't need editors to see) however the changed Alias names are not displayed to users in the Editor Pop Up window - which defaults to the Feature Service names (Pic 2)
Am I missing something obvious......
