HelloI'm a newbie in ArcGis under Android.I would like to center the map on a specific point (for instance 33.666354, -117.903557).My activity is :
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.main);
mMapView = (MapView)findViewById(R.id.map);
//MapOptions topo = new MapOptions(MapType.TOPO, 23, -110, 9);
//mMapView = new MapView(this, topo);
Point esri4326 = new Point(33.666354, -117.903557);
Point esri102100 = (Point) GeometryEngine.project(
esri4326,
SpatialReference.create(4326),
SpatialReference.create(102100)
mMapView.centerAt(esri102100, false);
topo = new MapOptions(MapType.TOPO);
streets = new MapOptions(MapType.STREETS);
natGeo = new MapOptions(MapType.NATIONAL_GEOGRAPHIC);
ocean = new MapOptions(MapType.OCEANS);
mMapView.setEsriLogoVisible(true);
My xml file is :
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
tools:context=".ArcGisHelloWorldActivity"
<!-- MapView layout and initial extent -->
<com.esri.android.map.MapView
android:id="@+id/map"
mapoptions.MapType="topo"
</com.esri.android.map.MapView>
</LinearLayout>
So the map is open but with the world :[ATTACH=CONFIG]29973[/ATTACH]Thank you for your help
