I need some help with this script I am developing. I need the update cursor to overwrite the empty LOCALITY values in TWB_Property with the ADMINAREA from TWB_Suburbs that I have turned into a list. I know the code is a little messy and I also can not figure out how to display it all using this forum. Any help will be appreciated. Thank you.
code begins below.
# Import modules
import arcpy
import os
#Set workspace geodatabase
arcpy.env.workspace = "C:\Users\Harry\Documents\Uni\Semester 1 2016\GIS3407 GIS Programming and Visualisation\Assignment 2\Assignment2.gdb"
#Start an editing session
edit = arcpy.da.Editor("C:\Users\Harry\Documents\Uni\Semester 1 2016\GIS3407 GIS Programming and Visualisation\Assignment 2\Assignment2.gdb")
edit.startEditing(False, False)
# Create a list of suburbs
# Create an empty list
localityList = []
#Create the search cursor
rows = arcpy.SearchCursor("TWB_Suburbs")
#Move to the first row
row = rows.next()
#Append the list with the selected locality name
while row:
localityList.append(str(row.ADMINAREA))
#Move to the next row
row = rows.next()
print(str(len(localityList)) + " <-- # of suburbs")
del row, rows
# Make a layer of all of the properties with no locality value
# Create query
nullQuery = '"LOCALITY" = \' \''
# Create layer
nullLayer = arcpy.MakeFeatureLayer_management("TWB_Property", "TWB_Property_Layer", nullQuery)
field = "LOCALITY"
fc = "TWB_Property_Layer"
#Counter
counter = 0
# Select by location
indexCounter = 0
print localityList
for counter in range(0,len(localityList)):
localityQuery = '"ADMINAREA" = ' + '\''+ localityList[indexCounter] + '\''
localityLayer = arcpy.MakeFeatureLayer_management("TWB_Suburbs", "TWB_Sububs_Layer", localityQuery)
arcpy.SelectLayerByLocation_management("TWB_Property_Layer", "WITHIN", "TWB_Sububs_Layer")
parcelList = []
sRows = arcpy.SearchCursor("TWB_Property_Layer")
sRow = sRows.next()
while sRow:
parcelList.append(sRow)
sRow = sRows.next()
print ("There are " + str(len(parcelList)) + " empty locality fields in " + localityList[indexCounter])
numberParcel = int(len(parcelList))
with arcpy.da.UpdateCursor(fc, field) as cursor:
for uRow in cursor:
if uRow[0] == '':
uRow[0] = str(localityList[indexCounter])
cursor.updateRow(uRow)
arcpy.Delete_management("TWB_Sububs_Layer")
counter += 1
indexCounter += 1
del uRow
arcpy.Delete_management("TWB_Property_Layer")
