Hello, for context I am currently developing a way to have records automatically added to a "Master Results Table". I am using a feature layer in AGOL that has tasks enabled through Field Maps Designer. Within the EsriTask workflow, the field team will be required to complete a Survey123 form. There is n many Survey123 forms created, and the Field Worker is automatically directed to the appropriate survey from the feildmaps mobile app based on the equipment_standard of the esritask they are working on.
Thus there are many different survey results feature layers and only one task layer, each survey result has an equipment_code field. With that there is an implicit relation between the equipment in the Task Layer and the survey results.
With all of that being said, I am looking for a way to write all of the survey results to one large table so that I can display all the survey results in one place and create an experience builder application for the end user to filter through them all at once. My idea was to have a notebook script that would run whenever a new record is created in one of the survey results feature layers and add a new record to the master table containing the overall score (A calculated field generated by the survey based on the user's answers), and some of the fields from the task layer for that specific piece of equipment. Using the primary key, equipment_code, to filter the task layer and populate the required fields in the master table with the equipment's overall score field from the survey. This would create a one to many relationship between the Task Layer and its many results in the master table.
I would love to get some feedback on an optimal approach to this, one concern I have with using "Tasks" in ArcGIS Pro is the cost of credits. I would like to avoid using credits if possible. Please comment any questions or clarifications needed. Thank you for your time!
