Hello. Having trouble with contour labels. Using the Maplex engine. Have a reference scale set in the map. Have set feature weights for all layers to 1000 (both feature and polygon boundaries as appropriate), except for contours which have a weight of 1. Have set the barrier weight for all graphics to high. Have set the label buffer to as high as it will go (50%). Remove all duplicates is set. Set the minimum label repeat to 2000 map units (feet). Contour labels are still drawing over features and graphics. Setting labels as background doesn't help.
These are literally part of the backdrop to a map so I really don't care where they're placed, so long as they're at the bottom. Switching them to graphics or annotation is fairly impractical because, again, I don't really care where they are placed as long as they're at the back.
What am I doing wrong? Any suggestions on things to try? Thank you!
