A few years ago, I wrote Dashboards That Pop: Category Selectors. I recently got a request to write an updated version since there have been all sorts of selector updates since then. I'm not going to rehash any tips that I shared in the previous blog post, so be sure to read that one if you haven't already and are looking for selector tips. Just be warned that the 'None Section' is no longer relevant in ArcGIS Online (and likely future versions of Enterprise). That capability has been replaced by the Require selection toggle.
Now on to the fun stuff.
Break Up Long Selector Lists
Let's make a simple dashboard using the National Weather Service's USA Weather Watches and Warnings layer.
Over 100 categories! That is going to make an event category filter frustrating to use for the average user.
That is a lot of categories to pick through. The options don't even fit on the screen. What if I only care about flood events? I have to pick through finding all the different flood categories. That's annoying and prone to error.
Toggling on search can help, but it's not perfect. What if I care about winter weather? There is no single search term that will find all these wintery categories:
- Extreme Cold Warning
- Winter Weather Advisory
- Freeze Warning
The ideal solution would be to add another field to group some of these categories together. But that is not possible as we do not own the data. An Arcade Data Expression is also not helpful as that would not filter the map.
Defined Values for the Win!
What I like to do in these situations is to use a series of filters to break out the categories into meaningful options.
Toggling on the Show select all option, ensures users can one-click enable the entire filter category. While the select multiple behavior allows users to further customize the filter.
Set Up
Create a category select for each overall grouping you want to provide to the user. Use Defined values, so you have full control over the options displayed. Remember that the Value must exactly match what is in your data to filter. If your filter field uses coded domains, this would be the code and not the label.
Enable Multiple selection and select all.
Set up your actions and then repeat as needed.
💡Tip: You can place categories in multiple groups if it makes sense to. For example, I may add the Blizzard Warning category in a Winter Weather group and a Wind group.
Dates, Dates, and More Dates
Date selectors now have three distinct modes:
- Slider (Date picker > Slider)
- Calendar (Date picker > Calendar)
- Defined options
So which date mode should you use for your dashboard? Well, it depends on the dashboard and how your users will use it. To build a successful dashboard, you need to have a solid understanding of how it will be used. This will help you determine which date selector mode will work best.
Let's walk through each mode and discuss the types of dashboards and use cases that each mode works best with.
Slider
Consistent & Consecutive Time Blocks
Users can easily step through hours, days, months, or years of data with the swipe of a mouse. Alternatively, set the Slider to a range and allow your users to create their own rolling window to explore.
Configuration:
- Type: Date picker
- Display mode: Slider
Defined Values
Standardized Time Blocks
Defined values let users quickly view and compare preset time blocks that are not consistently sized. I use them a lot in KPI and Executive dashboards where they need to understand where their metrics are today, this month, this quarter, and the year.
Configuration:
Click the +Add button to add as many options as you'd like. Provide each option a display name and set the time value (specific day(s)) or period.
Calendar
Ad-hoc Date Support
Calendar mode is a good option when you have a dashboard focused on individual events. For example, you may have a dashboard of maintenance requests. Users might need to filter these requests by request day to easily find specific open requests to view pertinent details. The specific request they are looking for dictates the date filter needed, and they may be jumping from date to date. Their date filter history might look something like:
- August 23, 2026
- July 6, 2026 – July 10, 2026
- August 26, 2026
- June 1, 2026 – June 2, 2026
Additionally, the Calendar mode works well if you don't know how your users will be working with dates in your dashboard. The ability to set clearly defined dates or date ranges gives your users the most flexibility.
Configuration:
- Type: Date picker
- Display mode: Calendar
Mix and Match
So, what do you do if dashboard has a mix of date needs? For example, your KPI dashboard makes sense to use defined options for the data selector, but occasionally there is a need for executives to be able to run numbers for ad hoc time periods? In this scenario, it makes sense to include two date selectors. One for defined options and the other for the calendar picker.
If you are going to do this, I recommend naming each selector clearly and distinctly. Especially if you are using the accordion or dropdown presentation mode that hides the bulk of the filter by default. Additionally, you can use the presentation modes to bring attention to the "primary" date filter by setting that one to Inline, while collapsing the secondary one.
Happy Dashboarding!
Dashboards That Pop Series
