I would like an option, when right clicking an item in the Contents pane to Remove and delete a layer if it is stored in a local GDB. I sometimes do a calculation, realize that something is wrong with the output name, and then remove it from the map so I can redo it, but the incorrect version remains in the GDB. Then I have to manually remove it from the GDB. Add a confirmation dialogue: Are you sure you wish to delete this from the GDB?
