I have created and published some simple surveys using the online builder. When I try to make small edits to the survey and publish the changes, I am unable to publish, with the error "Failed to fetch".
The edits are minor e.g. adding 'hint' text to a question or changing the validation (from 'required' to 'not required').
Initially I thought the error was due to moving the form and feature layer to a new folder (already discussed in this post) (https://community.esri.com/t5/arcgis-survey123-questions/survey123-updated-form-will-not-publish/m-p/879153#M30110) - the first survey I created, I moved to a new folder after creating. However for subsequent surveys I have not moved any items from their original folders - I have tried Save As to make a new copy of the survey, and have also tried starting from scratch, I have also cleared cookies. It is the same problem each time - I can publish initially, but I can't publish any updates.
The surveys do use a repeat (one repeat in each survey with 8-10 questions) - this is my first time using repeats from the online builder. There are no conditional questions/no visibility parameters etc.
Any suggestions appreciated!
