I was wondering if anyone else SEEs the issue described below with the UninstallPath key within the registry for HCLM? I'm asking if this is 'normal' for ArcGIS Pro 3.5. Thank you! basically looking for a yes/no answer 😉
Specifically, I'm looking at:
- Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ArcGISPro
- Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ArcGISPro Update356
- Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ArcGISPro Update357
- Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ArcGISPro Update358
I'm see the UninstallPath has an extra '\', which makes the path unreachable. The value I have is "c:\Program Files\ArcGIS\Pro\\Support\ESRI.exe"; in addition, at that location there is no ESRI.exe to be found.
I'm troubleshooting an install failure and this was one thing I notice. The '\\' would throw a security error if the path were used since it is a malformed UNC path.
Richard
