Hey, I am currently looking at different apps for field work. Since I am new to ESRI Field Maps so I need a little help to get a good idea of its possibilities.
There are a few main wishes I want to incorporate in our field apps. Can anyone, please, tell me if it is possible in Field Maps without slowing down its performance.
- For our ecological surveys we have a short list of target species. These are the species we look for in the field. However, this list does not cover all the species we encounter in the field. We often find species that are not on the list but are important to record. Therefore, I always want to have an option to search an extensive species list (+ 90.000 species). This complete list is composed of species name and species group. To speed up the searching for a species, it would be fine to first filter the list on species group. So, if I type a few characters its only search in, let's say, a few hundred bird species instead of all 90 thousand species.
Thus, is it possible in Field Maps alter the dropdown-list according to a value in another field? And is it possible to search the list by entering a few characters? - For certain monitoring protocols the research area is divided in a 100×100m grid. Each grid cell should be visited in the field. For this protocol it is mandatory to track your position as well. To control the project progress and to check if all grid cells are crossed, I want to use an expression-based symbology on the grid. When the tracking line is intersecting with a grid cell it should change colour at refreshing the map. So, in the office it is easy to check if cells are missed.
Thus, is is possible in Field Maps to add an expression-based symbology? And it is possible to use the active track for the symbology? - When adding a new observation I want to have a build-in check for an active track. This should actively remind the fieldworker to activate the track and the fieldworker gets a warning when the position tracking has stopped for some reason.
- Our observations layer should have an updating symbology based on the time of recording. When an observation is added more than 8 hours ago it is an old observation of a previous visit. All those observations should be grey while the recent observations (less than 8 hours old) should be red. The fieldworker can turn both categories on / off, depending on the situation.
Like I said I am new to Field Maps and ArcGIS Pro. The tutorials I have read and the video's I have seen do not explain the features I want. According to the information I have found "contingent values" could help to filter the dropdown list, but it is not working with extremely long lists like I have.
I also found that the position tracking is not available for Arcade expressions. Thus, the symbology of the grid cells, as I explain, above should not be possible.
Can anyone help me and perhaps send me a tutorial to get me on the right track if the above features are possible.
Thanks in advance!
